05-06-2015 02:48 AM
I am pretty baffled about this problem. I have a Graph binded with an array of Chartcollections. The charts are filled paralelly. Sometimes, quite randomly, I get this exception. In this case i had three plots displayed:
System.ArgumentOutOfRangeException was unhandled
HResult=-2146233086
Message=Slice range must fall within the size of the buffer.
Parameter name: length
Actual value was 3.
Source=NationalInstruments.Common
ParamName=length
StackTrace:
at NationalInstruments.Restricted.Guard`1.Satisfies(Boolean condition, Func`4 exceptionCreator, String format, Object[] args)
at NationalInstruments.Restricted.NIValidation.IsInRange[T](Guard`1 guard, Boolean isInRange, String format, Object[] args)
at NationalInstruments.DataInfrastructure.Primitives.RawDataStore`1.Slice(Int32 startIndex, Int32 length)
at NationalInstruments.DataInfrastructure.Buffer`1.Slice(Int32 startIndex, Int32 length, Func`2 traitFilter)
at NationalInstruments.DataInfrastructure.Buffer`1.NationalInstruments.DataInfrastructure.IBuffer.Slice(Int32 startIndex, Int32 length)
at NationalInstruments.Controls.Internal.DefaultAdjusterStep.a(IDictionary`2 A_0)
at NationalInstruments.Controls.Internal.DefaultAdjusterStep.c(IDictionary`2 A_0)
at NationalInstruments.Controls.Internal.DefaultPipelineDataProcessor.a(DefaultDataItemDescription[] A_0)
at NationalInstruments.Controls.Internal.DefaultPipelineDataProcessor.a()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.Run()
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at MyProject.FinalTest.Specific.GUI.App.Main() in c:\Sandbox\Specific2\MyProject.FinalTest.Specific.GUI\obj\Debug\App.g.cs:line 0
at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ThreadHelper.ThreadStart()
InnerException:
I dont even know where to start looking! Can someone please give me some pointers? Thanks!
05-06-2015 10:37 AM
By "The charts are filled parallelly", I take it that you are always appending to all the charts at the same time? Or do you mean appending to the charts on a different thread? (If the latter, because the chart collections are not thread-safe, you would need to marshal appends to the UI thread.)
Unfortunately, I was not able to reproduce the slice error you are seeing. I used three ChartCollection<double>
instances, and tested appending the same number of samples to each and different number of samples to each from a dispatcher timer, using one or two vertical axes. If you could provide a small sample application that reproduces the error, it would greatly simplify debugging your issue.
As a workaround, you may want to use the suggestions from this answer about disappearing charts. This will prevent the slice method from being called, which should avoid the issue entirely.
05-07-2015 03:24 AM
I found the problem!
I had a timer calling the method, which updated the plots from a queue. If there were too many signals, the emptying of the queue could take longer than the next timer call, and two threads tried to acces the charts paralel. I know set the timer inactive for the queue reading and turn it on after, and the problem looks solved!
Thank you for the idea bouncing, it was the direction I needed to start looking!
