02-04-2015 01:56 AM
Hy,
I just installed Measurement Studio for Visual Studio 2008 of the latest Developper Suite (August 2014).
I also installed LabVIEW 2014 and the needed updates.
On the computer, I find the release 13.0.35.190 of the NationalInstruments.Common.dll.
I installed the same Measurement Studio for Visual Studio 2008 on a second computer but I don't install LabVIEW because I don't need it.
The release installed is 13.0.35.188.
What should I install to have the same release (13.0.35.190) of the assembly on both computers.
I don't understand why it's not the same.
Best Regards,
CFOE
02-04-2015 03:06 AM - edited 02-04-2015 03:08 AM
in "C:\Program Files (x86)\National Instruments\MeasurementStudioVS2008\DotNET\Assemblies\Current"
On NationalInstruments.Common.dll properties, details tab, what's the version # on both computer ?
do you use any NI Cards / NI-DAQmx ? Installing NI DAQmx 14.0 (if needed) on both computers may update your NationalInstruments.Common.dll file
02-04-2015 10:37 AM
Thanks CharlyD,
NI-DAQmx 2014 was not installed, that's why i didn't have the good assembly.
CFOE
