ScatterGraph invert X and Y axis
Hi to all,
Is there a quick and easy way to invert X and Y axis in a ScatterGraph (ie: have the XAxis be up and down and the YAxis be left and right)?
Obviously, just plotting Y vs X instead of X vs Y for my plots is not the answer I am looking for. X and Y axis objects have different characteristics so I really need to actually invert them for display purposes.
I thought there might be a property for the ScatterPlot for this but it doesn't seem to be the case.
CD
(4,321 Views)
Set the XAxis.Inverted and/or YAxis.Inverted property to true.
Vijet Patankar
(4,319 Views)
I actually meant inverting the x with the y axis, as in x axis is on the left and y axis is at the bottom.
CD
(4,311 Views)
Could you give us a screenshot?
And, I am wondering why you would choose to do so!
Vijet Patankar
(4,308 Views)
It is for display purposes. I want to be able to show x at the bottom or on the side, without having to replot manually the numerous objects already there .
Also, i need mouse over events to return x and y correctly without having to write code such as
If x axis is at bottom
Else
(4,303 Views)
