I've come across a problem involving the PlotAreaClick event for the ScatterGraph web control. What I've noticed in my project is that when the user clicks on a point in the graph, the PlotAreaClick event fires as many times as the user has clicked points. For example, if you click on one point, it fires once; however, if you click on a second point, it fires twice, a third point, three times, and so on. This only happens when running in Internet Explorer (version 7). It looks like IE7 is archiving the screen coordinates that the user clicks on, and when you click on a second point, the event will fire with the coordinates for the first point, then again with data for the new point.
Also, in what may or may not be an unrelated matter, the AutoRefresh_Refresh event also causes the PlotAreaClick event to fire repeatedly after the user clicks on one point. This also only occurs in IE.
This also happens regardless of whether you run your website locally or you set up on a local server (IIS in my case).
I've created a very simple AJAX-enabled website that I will include with this post. Basically, you can click on the graph and you will see the coordinates for the nearest point at the top of the screen. If you run the website in Visual Studio (2005 in my case) and set a breakpoint at the PlotAreaClick event, you'll see this phenomenon.
Is there a setting in IE7 that I can change to prevent this from happening? Or is it the way I've set up my project? I'd appreciate any help that anyone could provide with this.
Justin
