Scan for instruments to save adresses
i want to scan for the instruments which are connected to my GPIB-card such as the
Measurement & Automation Explorer - Tool "Scan for Instruments", in a function in VB .NET, to see which instruments are connected at start-up and to save the addresses.
My current program runs with hard-coded addresses.
Can anyone help me creating this function or has anyone some ideas?
(4,122 Views)
Use this code to get a list (array of strings) of all GPIB Devices found on your system:
string[] devices;
       NationalInstruments.VisaNS.ResourceManager MyManager = NationalInstruments.VisaNS.ResourceManager.GetLocalManager();
       devices = MyManager.FindResources("GPIB?*INSTR");
Hope this helps!
(4,114 Views)
Thank you, I will test it tomorrow.
But I found an other Funktion called FindLstn (boardID%, padlist%(), resultlist%(), limit%).
I tried to work with this function, but I don't know where I get teh padlist!?
The padlist is a list of primary addresses that is terminated by NOADDR.
How do I word with this function?
(4,090 Views)
From a .NET standpoint this works for retrieving all available USB resources.
Public Function ResourceList() As Array
Try
Dim VisaRMLocal As NationalInstruments.VisaNS.ResourceManager = VisaRM.GetLocalManager
Return VisaRMLocal.FindResources("USB?*INSTR")
Catch ex As Exception
MsgBox(
"Error retrieving resource list: " & ex.Message)
End Try
End Function
(3,815 Views)
