06-04-2012 10:23 AM
06-04-2012 04:20 PM
So i found this procedure in vb by Agilent that is suppose to do the thing
but the problem here is that with IO.Read(4) , the bytes i recieve in a byte array aren't coming right , first byte is always wrong , rest of them are fine but with reverse order. for e.g if i get 10, 70, 2, 0 when i read a single reading from instrument. if i divide the reading from instrument by scale factor , it's give the DINT value and if i convert that to byte array , it gives 110(first byte changed),0,2,70(rest order swaped)..what's going on here? ..even using this is not helping ..Am i doing something wrong in the configuration?..
Private Sub cmdMeasureNorm_Click()
Dim readByte() As Byte
Dim rdg() As Long
Dim reading() As Double
Dim i As Integer
Dim iscale As String
Dim numReadings As Integer
numReadings = txtReadings.Text
ReDim reading(numReadings)
ReDim rdg(numReadings)
timeResult.Text = ""
txtResults.Text = ""
timeResult.Refresh
txtResults.Refresh
StartTimer
With DMM
.WriteString "PRESET NORM" 'TARM AUTO, TRIG SYN, DCV AUTORANGE
'DINT good for 5-1/2 or more digits
.WriteString "OFORMAT DINT" 'FAST AND ACCURATE - 4-BYTE INTEGERS
.WriteString "NRDGS 15, SYN" '15 READINGS PER TRIGGER, SYN SAMPLE EVENT
For i = 1 To numReadings
readByte = .IO.Read(4) 'SYN EVENT, 4-bytes per DINT value
'build 4-byte long values
If readByte(0) > 127 Then 'negative
rdg(i) = CLng(-2147483648#) + (readByte(0) - CLng(128)) * CLng(16777216) _
+ readByte(1) * CLng(65536) _
+ readByte(2) * CLng(256) + readByte(3)
Else 'positive
rdg(i) = readByte(0) * CLng(16777216) + readByte(1) * CLng(65536) _
End If
Next i
'get instrument scale value and multiply
'with all long values to get instrument measurement
.WriteString "ISCALE?" 'scale factor for DINT format
iscale = .ReadString
reading(i) = Round((rdg(i) * Val(iscale)), 6)
Next i
timeResult.Text = EndTimer 'readings in hand
timeResult.Refresh
'output to textbox
txtResults.SelText = i & ": " & Str$(reading(i)) & " volts DC" & vbCrLf
Next i
End With
End Sub
06-05-2012 10:06 AM
Not anything related to NI. Contact Agilent.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
