02-09-2017 03:22 PM - edited 02-09-2017 03:22 PM
I have a set of buttons to change Graphs Adjuster value. It works fine but ONLY for the data that follows later... not the currently displayed data. Is there a way to apply it to the existing data?
Basically, I have some data displayed and
Thanks!
Solved! Go to Solution.
02-09-2017 03:52 PM
Unfortunately, there is no way to refresh the data automatically when a range adjuster changes. I have created a task to fix this in the next release of Measurement Studio.
As a workaround, you can manually call the Refresh
method on the graph to force an update with the new adjuster.
02-09-2017 03:59 PM
Thanks!
07-08-2019 04:45 PM
Just wanted to let you know this behavior was fixed in the Measurement Studio 2019 release.
