07-31-2006 03:56 PM
08-01-2006 09:41 AM
Hi Alan,
Since your application is using DAQmx, you will need to install the DAQmx driver onto your target computer. This will have all the appropriate DLLs you will need to run your application. Download the latest version of DAQmx (currently 8.1) here.
Hope this helps!
Best Regards,
08-01-2006 09:53 AM
Hi Jonathan,
Thanks for your reply. I do have the DAQmx driver (came with the USB 6008 device) installed on the production computer. I can run MAX and the device is working OK and reading input signals. However I discovered the version loaded on my development computer is 8.1.0 whereas on the production computer is 8.0.1. I may have a version conflict problem so I'll download and install the newer software driver for my production computer as you suggest.
I'll report back my findings.
Thanks much,
Alan
08-02-2006 06:52 AM
03-16-2007 09:30 AM
