Problem with task not writing to file
I have a problem where the file writing from a analog reading task will eventually stop working.  The acquisition will work normally but after a period of time (tens of seconds to tens of minutes) it will stop writing files.
The mode of operation is to continuously acquire and periodically switch to a new file.
The key functions are 'readTaskConfigure()' and 'AnalogInCallback()'.  The 'ShowWaveforms' flag is set to false.
I suspect the problem is with resource usage.  Any suggestions on how to make this more efficient would be greatly appreciated.
Lorne Vaasjo
(4,780 Views)
Hello Lorne.V.
Does it give you any error message or display any information when it stops writing files?
Also, have you seen our text-based examples? They are installed with NI-DAQmx. In National Instruments/NI-DAQmx/Text-based Code Support.  Maybe there are examples that could help you verify what is missing.
Regards
Ernesto
(4,759 Views)
