I have just upgraded from Measurement Studio 8.0.1 to 8.1 using VS2005
I had an application using a ScatterGraph that when I try and rebuild it using 8.1 I get an error when trying to instantiate the control using:
this.graphPressures = new NationalInstruments.UI.WindowsForms.ScatterGraph();
The error is:
System.MethodAccessException was unhandled
Message="Attempt to access the method failed."
Source="mscorlib"
If I create a new project I can add a ScatterGraph which works without any problems.
If possible I want to fix this problem without recreating the project and copying all the code as it is quite a large project. Any Ideas?
