03-25-2016 08:30 AM
Is there a way to pass on our custom Button style to GraphInteractionPalette?
Redesigning GraphInteractionPalette from scratch in Blend isn't something I want to persue.
Thank you!
03-25-2016 11:30 AM
Unfortunately, the template for the graph interaction palette uses a fixed style to configure the buttons. I have created a task to address this in a future Measurement Studio release.
As a workaround, you can use the skin example in the attached XAML file as a starting point.
03-25-2016 11:37 AM
OK, thank you for the quick feedback!
07-08-2019 03:15 PM
Just wanted to let you know that Measurement Studio 2019 added a ButtonStyle
property to control this directly:
<ni:GraphInteractionPalette> <ni:GraphInteractionPalette.ButtonStyle> <Style TargetType="ButtonBase"> <Setter Property="Width" Value="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type ni:GraphInteractionPalette}}, Path=ButtonSize.Width}" /> <Setter Property="Height" Value="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type ni:GraphInteractionPalette}}, Path=ButtonSize.Height}" /> <Setter Property="Padding" Value="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type ni:GraphInteractionPalette}}, Path=Padding}" /> <Setter Property="ToolTipService.ToolTip" Value="{Binding}" /> <Setter Property="Content" Value="{Binding}" /> <Setter Property="ContentTemplateSelector"> <Setter.Value> <niPrimitives:NamedTemplateSelector /> </Setter.Value> </Setter> <!-- style customization --> <Setter Property="Background" Value="LightGreen" /> <!-- style customization --> </Style> </ni:GraphInteractionPalette.ButtonStyle> </ni:GraphInteractionPalette>
As you can see, this still requires duplication of standard bindings to get standard behavior. This can be simplified with some code to pull in the default button style:
Code: public MainWindow() { var defaultPaletteStyle = (Style)this.FindResource(typeof(GraphInteractionPalette)); var baseButtonStyle = defaultPaletteStyle.Resources.Values.OfType<Style>().Single(s => typeof(ButtonBase).IsAssignableFrom(s.TargetType)); this.Resources["BaseButtonStyle"] = baseButtonStyle; InitializeComponent(); } XAML: <ni:GraphInteractionPalette> <ni:GraphInteractionPalette.ButtonStyle> <Style TargetType="ButtonBase" BasedOn="{StaticResource BaseButtonStyle}"> <!-- style customization --> <Setter Property="Background" Value="LightGreen" /> <!-- style customization --> </Style> </ni:GraphInteractionPalette.ButtonStyle> </ni:GraphInteractionPalette>
07-08-2019 03:42 PM
Thank you, Paul!
I actually just realized that 2019 is out and was wondering what changes were made. I mean, I see the release notes but there isn't much unless I'm looking at a wrong link.
I will have to order 2019 then.
Thanks!
07-08-2019 04:12 PM
Specifically for the WPF controls, the 2019 release was focused primarily on performance and bug fixes (so fewer high-level things to announce; it just works better :)).
