Hi ppodlevs,
These methods have been obsoleted for quite a while, and eventually they will be removed all together. Furthermore, for new users and/or new projects, these methods do not show up under the intellisense menu, so using them has be intentional. I understand that in your case you are upgrading and trying to bring your program up to speed, and you are right to do so.
In general, most programmers have a requirement to use a specific algorithm, and the newer functions now give them that option. If you don't know which method you need to use, or if you don't care, you could just choose the first option in the enum. If you just want it to perform like before, you could also try each option and compare the results with the old functions.
In the case of
LinearFit, the old
functions used the least square fit method by default, so you can draw a 1-to-1 correlation between calling the old functions and calling the new functions with
FitMethod.LeastSquare.
