03-22-2012 05:51 PM
HI,
I AM USING VISUAL STUDIO 2005, AND USING ni daq DRIVERS version 8.9.
when i try to build my project i get following error.
Error 1 The type 'NationalInstruments.ISynchronizeCallbacks' is defined in an assembly that is not referenced. You must add a reference to assembly 'NationalInstruments.Common, Version=8.6.35.131, Culture=neutral, PublicKeyToken=18cbae0f9955702a'. C:\Test_proj_nagraj\PowerTools\DaqInterface\DaqDeviceInterface.cs 200 22 DaqInterface
i want to make sure that my tool works with the nationalinstruments.common version=8.6.20.131. currently my project points to this dll.
is there a way to fix this?
03-23-2012 10:21 AM
If you are using Visual Studio 2005 with the .NET 2.0 Framework, make sure that all of the National Instrument assemblies referenced in your project are for 2.0. You can tell what version of the .NET Framework NI assemblies are for by looking at the third number in the version number (ex: 8.6.35.131 is for .NET 3.5).
03-23-2012 10:54 AM
currently all my dll refereneces are pointing to the 2.0 version only. but still it gives me the above error.
before few days i had installed few 3.5 version dll files. but now i have removed them.
could there be any other problem?
03-23-2012 02:13 PM
hey,
problem is solved.
my nationalinstruments.Daqmx.dll was pointing to higher version as opposed to others. changed it to point to 8.6.20.131 and things are working now.
thanks
01-18-2013 08:36 AM
Hello everyone,
I have similar problem as you, when trying to build program Cicero word generator in VS2010. There error occurs:
C:\Documents and Settings\Krystian\Moje dokumenty\D_LIS_labview\STanik\Cicero-Word-GeneratorV2\AtticusServer\ServerRuntime\RS232Task.cs(49,16): error CS0012: The type 'NationalInstruments.ISynchronizeCallbacks' is defined in an assembly that is not referenced. You must add a reference to assembly 'NationalInstruments.Common, Version=9.0.35.362, Culture=neutral, PublicKeyToken=18cbae0f9955702a'.
I tried to change NationalInstrumments.Common Properties/Specific version to False, but error remains. I am new to .NET , do you think that adding something to the app.config file could help ?
I had similar problem with SimpleReadWrite from .NET4.0 NI-Visa examples, but changing "NationalInstrumments.Common" "Properties"/"Specific version" to False solved problem.
Could You tell me what should i try - what component of my system i should reinstall ?
In attachments there are printscreens of my configuration.
Krzysiek
01-18-2013 11:14 AM
This is a common error if you are using the .NET 4.0 Client Profile. Measurement Studio only supports the full .NET 4.0 version. In the project properties, change the Target Framework to ".NET Framework 4".
02-03-2015 10:10 AM
Hi all,
I have NIDAQmx version 9.7.5 installed, and I am trying to use an ATEasy project that uses NationalInstruments.Common assembly. It constantly retrieves me the error:
Run-time error #420 : 'Object method or property 'Init' failed: Could not load file or assembly 'NationalInstruments.Common, Version=8.5.35.149, Culture=neutral, PublicKeyToken=18cbae0f9955702a' or one of its dependencies. The system cannot find the file specified.' found in 'Ni_Generic.InitAnalog' in line 26.
What to do?
Please help me!
Alex
02-04-2015 04:59 PM
Hi Alex,
It will probably be more beneficial to you if you post the error you are experiencing to a new forum post. Your question will then have much higher visibility, thus generating more responses.
Thank you!
