NI Spy with Net
I've noticed that spy is showing ibfind calls for boards GPIB1 thru 9 and I have only one gpib "board" that is gpib0 (it is indeed found and operational).  Did not happen with the non net.  Is there some configuration that is causing this repeatative ibfind for other gpib cards ?
(2,958 Views)
I have some additional questions for you to troubleshot this issue. Are you seeing any errors in your application when you use ibfind? Or is it just in NI-Spy? Which language (VB, C++, C#) are you using in .NET? Can you post the NI-Spy captures? Are you using .NET 2003 or 2005? What version of NI-488.2 are you using?
Thanks!
Missy S.
Project Engineer
RoviSys
(2,939 Views)
I see the calls with just Spy on. Nothing else running. Am using VB.net 2005 for application.
(2,919 Views)
