03-30-2015 10:59 AM
Anyone have any luck with using Switch Executive through Visual Studio/Measurement Studio? Can't find any class libraries like there is with other NI devices (DMM, SCOPE, etc) on NI's site. I tried to use the IVI Instrument wizard through Measurement Studio but it doesn't even convert it to something that is able to be compiled... it tries to PInvoke on niSE_32.dll which doesn't even exist on my system with NISE 3.6 installed. I finally wrote a DLL in CVI where I wrap Switch Executive's API into something I can manually PInvoke from C#, but that seems like a roundabout way to do it.....
03-31-2015 03:07 PM
Hi taft220,
Unfortunately it does not look like we have any .NET libraries for Switch Executive. I believe that Switch Executive only has C dlls available, based on the note in this document: ftp://ftp.ni.com/support/switchexecutive/Eval/Documentation/Getting%20Started%20with%20NI%20Switch%2...
Its sounds like the way you have found to get around this issue is in fact the likely workaround.
04-12-2017 01:14 PM
Hi taft220,
I am using C# as well and was curious if you would share your PInvoke wrapper of the Switch Executive API's?
Example of niSwitch_init function
[DllImport("niSwitch_32.dll", EntryPoint = "niSwitch_init", CallingConvention = CallingConvention.StdCall)]
public extern static int init(string Resource_Name, ushort ID_Query, ushort Reset_Device, ref System.IntPtr Instrument_Handle);
AG
04-13-2017 04:20 PM
Hi AG,
taft220 might not be watching this post anymore since it is a couple of years old. I found some links that indicate you should be able to use Switch Executive with Measurement Studio, including the below white paper.
http://www.ni.com/white-paper/3724/en/
The below example may be helpful to you. The link is unfortunately broken, but I have reported it and hopefully it will be fixed soon. However, the example program is able to be downloaded.
http://www.ni.com/example/26648/en/
