11-11-2015 08:14 AM
Hi
Is there a way to make tow different Y axis from both the right and left sides of the graph, with different scal, sharing the same X axis?
How does one refer in code to these?
Solved! Go to Solution.
11-12-2015 12:03 PM
Hi Gabe 1977,
You can edit the Y Axes on your graph by right-clicking the graph and selecting "Edit YAxes...". Here, you can add multiple axes and, under Layout in the Properties tab, you can edit the CaptionPosition and Position of each axis. You can set the these properties to Left for one axis and Right for the other.
Hope this helps!
11-15-2015 01:03 AM
Hi Jupiter02
First, thanks.
I am talking about visual studio. I couldn't find the properties you wrote about...
11-16-2015 10:15 AM
Julia's response correctly describes how to configure the Windows Forms graph control in Visual Studio. If you are using the WPF graph control, the procedure is a little different:
Axes
.Location
of each axis to the Near or Far side of the graph.Label
and Range
to distinguish the two axes.Name
if you want to refer to the axis in code.You can also add multiple axes in XAML or code, as described in the Configure Measurement Studio WPF Graph Control Axes and Cursors how-to topic (it is the last example in the Axes table).
11-17-2015 01:47 AM
Thanks!
02-10-2017 12:57 PM
Hi Paul,
I have 2 ni:AxisDouble but I'm not sure how distribute data between them.
My data object is double[4][] and I'd like to apply the 4th data set to the Far axis.
Could you please let me know how this works? At the moment they are all related to the main axis.
Thanks!
02-10-2017 01:14 PM - edited 02-10-2017 01:20 PM
To associate a plot with a particular vertical scale, you will need to set the VerticalScale
property on that plot. For your case, where you want to associate the fourth plot with the second vertical axis, you can setup your XAML like this:
<ni:Graph ...>
<ni:Graph.Axes>
<ni:AxisDouble x:Name="v1" Orientation="Vertical" ... />
<ni:AxisDouble x:Name="v2" Orientation="Vertical" ... />
</ni:Graph.Axes>
<ni:Graph.Plots>
<ni:Plot Label="First Plot" />
<ni:Plot Label="Second Plot" />
<ni:Plot Label="Third Plot" />
<ni:Plot Label="Fourth Plot" VerticalScale="{Binding ElementName=v2}" />
</ni:Graph.Plots>
</ni:Graph>
02-10-2017 03:20 PM
Thank you!
02-28-2019 12:58 PM
Hello.
I understand how to assign a plot to a second axis (e.g. on the right side of the graph) at design time using the property page. However, I require making the assignment at run time. I have 2 Y Axes, index values 0 and 1 from the YAxis property pages at design time. The following code does not work (everything is plotted on YAxis1 (index 0):
For i = 1 To gintNumStripChartItems
'Sets the line color for each sensor on the chart
Strip.Plots.Item(i - 1).LineColor = gaStripChartItem(i).Color
'Sets the line width for each sensor on the chart
Strip.Plots.Item(i - 1).LineWidth = 2
''Assign a plot to the proper Y axis (left or right, since there are only 2)
Strip.Plots.Item(i - 1).YAxis = Strip.YAxes.Item(gaStripChartItem(i).TrackID)
Next
The variable gaStripChartItem(i).TrackID has the values 0 or 1 only.
What am I doing wrong here ?
Thank you
