03-10-2015 10:09 AM
I want to use multiple y-axes in a WaveformGraph to scale single waveforms without caching all data points and plot them again.
The attached minimal sample shows the behaviour with and without multiple y-axes. In the screenshot “MultiAxes.png” each waveform has its own y-axis. In the screenshot “SingleAxis.png” all waveforms use the same y-axis. Without using multiple y-axes the time to reconfigure the graph reduces from 3.3 seconds to 0.5 seconds.
How can I shorten the time to rebuild the WaveformGraph without omit use of multiple y-axes?
Stephan
03-11-2015 11:08 AM
Hi Stephan,
Would you please give me the details about which Visual Studio/Measurement Studio you are using?
Best regards
Christoph
03-12-2015 06:02 AM
Hi Christoph,
I am using Visual Studio 2012 and Measurement Studio 2013.
Stephan
03-12-2015 06:45 AM
Hi Stephan,
I would like to point you to the source code. There you see a clear difference in behaviour between only one axis and multiple axes. The for loop runs either 1 or number of waveforms (e.g. 200) which should account for a difference in computation time.
if (true == mMultiAxesCheckBox.Checked) axesCount = mWaveformCount; else axesCount = 1; for (int i = 0; i < axesCount; i++) { var yAxis = new YAxis(); SetAxisInvisible(yAxis); yAxis.Range = CalcRange(i, 1.0); yAxis.OriginLineVisible = true; yAxes.Add(yAxis); //mGraph.YAxes.Add(yAxis); }
Best regards
Christoph
03-12-2015 08:51 AM
Hi Christoph,
Thank you for your fast answer.
As you can find in row "Axes created" of the following table the loop you point to consumes only 12 ms of the CPU time.
Axis Count |
1 Axis |
200 Axes |
200 Axes without optimization |
Clear axes |
14 ms |
943 ms |
2796 ms |
Axes created |
0 ms |
12 ms |
7 ms |
Axes added |
1 ms |
453 ms |
2373 ms |
Clear plot |
40 ms |
372 ms |
2336 ms |
Waveforms added |
37 ms |
393 ms |
2338 ms |
Plot samples added |
113 ms |
106 ms |
109 ms |
Clear annotation |
25 ms |
360 ms |
2312 ms |
Annotations added |
281 ms |
657 ms |
2650 ms |
Total |
535 ms |
3312 ms |
14938 ms |
The problem is that all actions on the graph take much longer if I add multiple axes however the amount of plotted data is the same.
I am searching for a optimization like I have used in the method SetAxisInvisible(). See the lines after the comment in the following code snipped. The time behaviour without this optimization I have added to the table above in column "200 Axes without optimization".
private void SetAxisInvisible(Axis axis) { axis.Visible = false; axis.Mode = AxisMode.Fixed; // the following lines doesn't change anything on the appearance of the axis because // the whole axis is invisible but they improve the performance of the graph drastically axis.AutoSpacing = false; axis.CaptionVisible = false; axis.EndLabelsAlwaysVisible = false; axis.MajorDivisions.GridVisible = false; axis.MajorDivisions.LabelVisible = false; axis.MajorDivisions.TickVisible = false; axis.MinorDivisions.GridVisible = false; axis.MinorDivisions.TickVisible = false; }
Stephan
