Hello
I have filed a report for futher investigation. It seems that the code is generated correctly and the runtime behavior is also correct, unless ofcourse you change the control in anyway, which would regerate the code-behind.
This seems to be isolated to the C++ .NET designer surface.
If I find anything else, I will let you know. But for now, I would recommend that you set this particular property in the form load event to ensure that it behaves correctly at runtime.
Sorry for the inconvienience.
Bilal Durrani
NI
