03-11-2007 01:20 PM
03-12-2007 12:39 PM
Hi Simon,
The short-answer to your question is YES, you can perform data acquisition in
C# without using Measurement Studio.
To do this, you can use the Measurement Studio DAQmx .NET API. This is far and away the easiest API to use to program DAQ cards in C#. This API is included in the DAQmx installer and does not require you to purchase Measurement Studio. However, without Measurement Studio you do not get the benefit of the DAQ Assistant integrated into Visual Studio .NET. The DAQ Assistant, when integrated into Visual Studio .NET, allows you to graphically configure your DAQ tasks, channels, and scales. It then generates a Visual C# class, referred to as a DAQmx task class. The DAQmx task class includes code that programmatically configures the measurement task that you created interactively. Additionally, the DAQ Assistant also generates a .NET DAQ component that uses the generated DAQmx task class.
When you install DAQmx, even though you might not have Measurement Studio, it will create a folder in C:\Program Files\National Instruments\ called MeasurementStudioVS2005 (or possible MeasurementStudioVS2003depending upon which .NET Framework support option you chose when installing DAQmx). This folder will consist of the DAQmx .NET assembly as well as examples that don’t require Measurement Studio. These examples are located inside the MeasurementStudioVS2005 folder under \DotNET\Examples\DAQmx.
To address your help and documentation
issue, the installed documentation contains the NI-DAQmx API overview,
measurement tasks and concepts, and function reference. This help is
fully integrated into the Visual Studio .NET documentation. To view the
NI-DAQmx .NET documentation, go to Start » Programs » National Instruments »
NI-DAQ » NI-DAQmx .NET Reference Help. Expand NI Measurement Studio Help
» NI Measurement Studio .NET Class Library » Reference to view the function
reference. Expand NI Measurement Studio Help » NI Measurement Studio .NET
Class Library » Using the Measurement Studio .NET Class Libraries to view
conceptual topics for using NI-DAQmx with Visual C# and Visual Basic
.NET. Even though Measurement Studio isn't installed, the topics still
use the Measurement Studio name.
Continued onto the next post......
03-12-2007 12:41 PM
In the Using the Measurement Studio .NET Class Libraries section, you will notice you can select a sub-category entitled Measurement Studio NI-DAQmx .NET Examples. This section describes a little bit about each example that is installed.
If you are not sure whether or not you would like to use our analysis or user interface components and features, why not try and download the evaluation version of Measurement Studio. This way you can see what we offer that may help your application.
Hope this clears things up. I know it can be somewhat confusing sometimes.
Best Regards,
03-12-2007 02:30 PM
Hi Jonathan,
Thank you very much for the comprehensive answer, truely appreciated.
Best regards
Simon
