Hi David,
Thanks for your reply.
The answers to your questions are:
>>1. Did all the controls dissappear, or just the Measurement Studio controls?
Only the Measurement Studio controls have ever disappeared.
2. Is this a recurring issue?
Yes, it has happened about six different times with different solutions. Sometimes if I close the solution without saving it, close VS and then restart VS and reopen the solution, the controls will be present. It once took 4 iterations of that sequence to get the controls to return! I have received the hotfix
KB842706 from Microsoft, but have not applied it yet. The "Copy Local" property for the Measurement Studio references is set to "False" when the controls are missing.
3. Can you try opening the individual form, instead of the solution?
Yes, I will try that the next time it occurs.
Mark
