04-08-2014 04:42 PM
I am attempting to read formula strings from an array of clusters. No problem, works great. Now I want to evalute the string formulas to determine if the values are greater or less than what is specified in the formula ( BatteryVoltage < 5.0 ). The current string to formula evaluate funtions do not handle "<>&|" operators. Any ideas that won't cost an arm and a leg???
Larry
04-09-2014 08:18 PM
Hi lcarner
One thing you can try is evaluating those values using the <>& nodes in LabVIEW. You can take the output values of the Formula Parsing VIs and evaluate them using the native LabVIEW comparison nodes.
Regards
04-11-2014 01:56 PM
I use the open source library muParser (http://muparser.beltoforion.de/) to evaluate mathematical expressions in my project Open Dyno www.opendyno.com.
01-30-2018 09:59 AM
A new LabVIEW API for muParser is available on LAVA: https://lavag.org/files/file/295-lv-muparser/
