Measurement Studio does not work under VS 2005 beta 2, because of component licensing. (run time license error)
System.Security.Cryptography.CryptographicException was unhandled
Message="Length of the data to decrypt is invalid."
Source="mscorlib"
StackTrace:
at System.Security.Cryptography.RijndaelManagedTransform.TransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount)
at System.Security.Cryptography.CryptoStream.FlushFinalBlock()
at System.Security.Cryptography.CryptoStream.Dispose(Boolean disposing)
at System.IO.Stream.Close()
at System.IO.Stream.System.IDisposable.Dispose()
at NationalInstruments.Restricted.LicenserHelper.Decrypt(String cypherText)
at NationalInstruments.Restricted.LicenseBase.a(String )
at NationalInstruments.Restricted.LicenseBase.RunTimeCheck(LicenseContext context, Type type)
at NationalInstruments.Restricted.LicenseProviderBase.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions)
at System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey)
at System.ComponentModel.LicenseManager.ValidateInternal(Type type, Object instance, Boolean allowExceptions, License& license)
at System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
at NationalInstruments.UI.WindowsForms.Led..ctor()
at WindowsApplication2.Form1.InitializeComponent() in I:\temp\WindowsApplication2\WindowsApplication2\Form1.Designer.cs:line 40
at WindowsApplication2.Form1..ctor() in I:\temp\WindowsApplication2\WindowsApplication2\Form1.cs:line 15
at WindowsApplication2.Program.Main() in I:\temp\WindowsApplication2\WindowsApplication2\Program.cs:line 16
at System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
