NI Home
Cart Cart | Help
You are here:
Reply
Member
Mattholemew
Is it Possible to Use other ASP .NET Controls with AutoRefresh
The AutoRefresh control works great with Measurement Studio WebForms controls, but is there a way to use AutoRefresh with other ASP .NET controls or custom HTML rendering?
Thanks!
-Matt
Active Participant
Al.B
Re: Is it Possible to Use other ASP .NET Controls with AutoRefresh
Hi Matt,
From what I have seen, the autorefresh control should work in the same way with Measurement Studio controls as it does with non-Measurement Studio ones; it is just necessary to manually enter the name of the non MS control. If this is not working, please provide a bit more detail about your application and I will look into the issue further!
Al B.
NI TestStand Product Support Engineer
CTA/CLD
Member
Haseeb
Hi Matt,
The AutoRefresh control works only with controls that implement the IRefreshCallbackEventHandler interface which the Measurement Studio WebForms controls do. If you want any non-MStudio control to work with the AutoRefresh, then you will have to implement this interface on that control.
Mohammed Haseeb|Measurement Studio|National Instruments
Member
Mattholemew
Thanks, Mohammed!  I'll give this a try!
-Matt
Member
taov
Hi Matt, have you got the answer on how to use other ASP.NET control with AutoRefresh?
I am stuck with the same case. Could you give me an answer?
Member
jallen88
taov,
I noticed that you posted a similar question at how to make asp.net customcontrol support autorefresh
I would encourage you to continue the discussion in one thread so that the resolution is in one place. You will find my reply to your original post at the thread linked above.
Jared A.
Applications Engineer
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
