Intensity graph gridlines not visible
Hi to all,
I cannot seem to get to show the grid lines on an intensity graph. They do show anywhere there is no data, but where there is data they are hidden. Is this a bug or am I doing something wrong?
    griStats.Plot(stats)
    intensityPlot.PixelInterpolation = True
    griStats.XAxes(0).MajorDivisions.GridLineStyle = UI.LineStyle.Solid
    griStats.XAxes(0).MajorDivisions.GridColor = Color.Black
    griStats.XAxes(0).MajorDivisions.Base = 0
    griStats.XAxes(0).MajorDivisions.Interval = 1
    griStats.XAxes(0).MajorDivisions.GridVisible = True
    griStats.XAxes(0).Range = New UI.Range(0, UBound(twa))
    griStats.YAxes(0).MajorDivisions.GridLineStyle = UI.LineStyle.Solid
    griStats.YAxes(0).MajorDivisions.GridColor = Color.Black
    griStats.YAxes(0).MajorDivisions.Base = 0
    griStats.YAxes(0).MajorDivisions.Interval = 1
    griStats.YAxes(0).Range = New UI.Range(0, UBound(tws))
    griStats.YAxes(0).MajorDivisions.GridVisible = True
Thanks for your help,
CD
(4,045 Views)
It looks very much like a z-order problem or something of the sort.
(4,039 Views)
Accepted by topic author cdouillet
Hey there,
Try this. Hook on to the IntensityGraph.AfterDrawPlot event.
private void intensityGraph1_AfterDrawPlot(object sender, NationalInstruments.UI.AfterDrawIntensityPlotEventArgs e)
intensityGraph1.DrawGridLines(new NationalInstruments.UI.ComponentDrawArgs(e.Graphics, e.Bounds));
Hope this helps.
Vijet Patankar,
(4,009 Views)
That worked great, thank you very much.
CD
(3,987 Views)
Hi, is this still the only way?  This solution is from 2011 so perhaps there's a setting instead of this "hack"?
By the way, I am using WPF so not even sure if this solution will work.
Thank you!
(3,380 Views)
This post does not pertain to WPF. Please create a new thread describing the issue you are seeing with the WPF graph.
Daniel Dorroh
(3,368 Views)
