07-20-2007 12:23 PM
I'm using a NI PCI-6221 to capture digital signals on an external clock. It all works fine, except that maybe once every week or so, I get an error message that an edge occurred too quickly on the external clock. I quote:
Digital input detected a new sample clock before the previous sample was latched into onboard memory.
If you are using an external sample clock [I am], ensure that it is connected, within the jitter and voltage level specifications, and without glitches. If applicable, reduce your sample clock rate or use a product capable of higher sample clock rates.
Task name: _unnamedTask<0>
Status Code: -200715
And after this error message appears, the task refuses to do any more acquisitions. I understand this error message, and I know it points to a systematic error in my setup. Nonetheless, I am hoping to "fix" this problem in software.
Question: Is there any way that I can make the DAQmx task simply ignore that bad reading, and keep going, instead of refusing to go on?
Thanks, Nick Johnson
07-23-2007 05:28 PM
