Hi Matt,
I have the same problem, but I do need to install NI Device drivers, I use simulated devices.
I start a thread http://forums.ni.com/t5/Measurement-Studio-for-NET/NIDaq-Windows-application-not-visible-in-new-proj... with no answer yet and I am stuck on that I cannot access the Daq assistant, I cannot use the daqmx function like stated in the example from the whitepaper NI-Tutorial-UsingDaqmx in Text ProgrammingEnvironements
Also I always get the error, when I try to create a new project:
Error 2 The project currently contains references to more than one version of NationalInstruments.Common, a direct reference to version 13.0.40.188 and an indirect reference (through 'NationalInstruments.DAQmx.Task') to version 13.0.40.190. Change the direct reference to use version 13.0.40.190 (or higher) of NationalInstruments.Common.
Which I correct by removing the 13.0.40.188 version and adding the 13.0.40.190 from the references to the project but I am not sure that is the best solution...
I guess the 40 in this dll version number is supposed to refer to the daqmx.NET 4 framework, and I my project is actually pointing to .NET 4.5 framework, could that be the problem? if yes how should I resolve it?
Thanks in advance for your help,
Best Regards,
