How to convert coordinates of the ScarletGraph into coordinates of the screen
I should to create on the graph
XYPointAnnotation and to show dialogue of input of the text for annatation. For creation annotation I have coordinates. How to translate these coordinates into coordinates of the screen (correctly to display dialog).
For an example,
I have there are two axes (time, temperature). I have coordinates (1min23sec, 35C). How to convert into coordinates of the screen?
P.S. Excuse for my bad English
(3,049 Views)
You should be able to use the MapDataPoint method of the XYPlot class to accomplish what you are looking for.  Below is some quick example code that demonstrates how to use the function.  The code below returns the device coordinates for the point 5,5 on the graph.  One thing to keep in mind is that the point that this returns is relative to the location of the Graph or Chart object not to the whole form.  Hope this helps!
PointF point;
Rectangle yaxis = waveformGraph1.YAxes[0].GetBounds();
Rectangle xaxis = waveformGraph1.XAxes[0].GetBounds();
Rectangle rect = new Rectangle(xaxis.X, yaxis.Y, xaxis.Width, yaxis.Height);
point = waveformGraph1.Plots[0].MapDataPoint(rect, 5, 5);
Pat P.
Software Engineer
(3,031 Views)
Thanks. Works very well
(3,022 Views)
