Jeff,
Probably the most presentable way to accomplish this task would be to
use XYcursors on the graph as limit lines. You can hide the
veritcal lines generated from the XYcursors by setting the
VerticalCrosshairLength property to 0. You can then obtain the current
Y axis position of the limit line by way of the YPosition property, and
then compare this limit value to the data points that are coming
in. This approach would allow the user to be able to set the
limits of the test by dragging the limit lines on the graph itself.
Another idea would be to have upper and lower limit numerical controls
on the side of the graph. The user would type the limit values
in, and the application would continually make comparisons between the
limits and the data points, and set a boolean to true if the point
falls outside the range.
Mike Torba
