09-12-2006 10:55 AM
09-14-2006 04:41 PM
We don't actually have full examples written for calibration for a couple of reasons. The calibration procedure will be different depending on the device you're calibrating and the equipment you're to calibrate. If an example program is not used correctly then it could damage your device. We have excellent tutorials available to learn how to write a calibration routine.
http://zone.ni.com/devzone/conceptd.nsf/webmain/b3587fbee5a1b6908625712a0074b5d8
http://zone.ni.com/devzone/conceptd.nsf/webmain/a0f40f3ea32b440d8625692e00544dc3
However, it looks like you previously had someone write a calibration routine in LabVIEW. I would suggest getting that routine to work again rather than write a new one. What possibly happened is you installed the newest driver CD which may have removed Traditional DAQ which is what the calibration routine used. The version of Traditional DAQ you'll use will depend on the LabVIEW version you have but most likely you'll use version 7.4:
Hope this helps!
B Spears
