01-28-2006 02:46 AM
02-06-2006 05:11 PM
02-07-2006 02:59 AM
02-14-2006 09:59 AM
02-14-2006 10:42 AM
02-27-2006 10:42 AM
Hi Russell-
After some investigation we found that this appears to be a problem with debug mode builds in C#.NET Express 2005 with the NI-DAQmx .NET API. By switching to a release mode build we were able to workaround the issue. Could you please give this a try and let us know if you're not able to see better results? We are currently looking further into the cause of the high CPU utilization, but for the timebeing this workaround should work well.
Hopefully this helps-
02-27-2006 11:22 AM
02-28-2006 02:37 PM
Hi Russell-
Can you please verify if the behavior persists with an NI-DAQmx shipping example for finite analog acquisition? "C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmx\Analog In\Measure Voltage\AcqVoltageSamples_IntClk\Cs" would be a good choice.
If so, please let me know exactly the build settings you are using and which configuration steps you are following and I will try again to replicate the problem on my end.
Thanks again-
03-01-2006 02:39 AM
03-06-2006 10:43 AM
