Hide & Show axes with BaselineStrokeThickness=0
Hey,
In my project I want to hide / show the Y axis, It works usually.
But when BaselineStrokeThickness is 0 and TickVisibility of the MinorDivisons is collapsed, I am able to hide the Y axis but can not re-present it.
I attach a project, for example.
(3,065 Views)
I was able to reproduce the problem, and have file a task to correct this in the next release.
As a workaround, you can trigger a manual referesh of the scale.  For example, adding the following changes to your example corrected the problem:
    public partial class MainWindow : Window {
        public MainWindow( ) {
            InitializeComponent( );
            ShowYAxis.Checked += OnShowYAxisChecked;
        private void OnShowYAxisChecked( object sender, RoutedEventArgs e ) {
            Dispatcher.BeginInvoke( new Action( delegate {
                NationalInstruments.Controls.Primitives.IScale scale = YAxis;
                scale.OnInvalidated( EventArgs.Empty );
(I used a BeginInvoke call, because the binding updates after the Checked event occurs. Depending on how you are setting visibility in your application, there may be a more appropriate place to put the workaround logic.)
~ Paul H
(3,038 Views)
Just wanted to let you know this issue was fixed in the Measurement Studio 2019 release.
~ Paul H
(1,723 Views)
