04-14-2015 07:40 AM
What am I doing wrong here and what do I need to do to fix it?? The following code is in the "OnTaskCreated" sub created by MS for custom task settings. I am declaring the scales (ch0Scale, ch1Scale, ...) above this code in the same Partial Public Class DaqTask1Component. What do I need to set the scale to and where in the code so that I am no longer getting the NullReferenceException error?
Thank you for any assistance provided.
Partial Public Class DaqTask1Component Private ch0 As AIChannel, ch1 As AIChannel, ch2 As AIChannel, ch3 As AIChannel, ch4 As AIChannel, ch5 As AIChannel, _ ch6 As AIChannel, ch7 As AIChannel, ch8 As AIChannel, ch9 As AIChannel, ch10 As AIChannel, ch11 As AIChannel, _ ch12 As AIChannel, ch13 As AIChannel, ch14 As AIChannel, ch15 As AIChannel Private ch0Scale As NationalInstruments.DAQmx.RangeMapScale, ch1Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch2Scale As NationalInstruments.DAQmx.RangeMapScale, ch3Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch4Scale As NationalInstruments.DAQmx.RangeMapScale, ch5Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch6Scale As NationalInstruments.DAQmx.RangeMapScale, ch7Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch8Scale As NationalInstruments.DAQmx.RangeMapScale, ch9Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch10Scale As NationalInstruments.DAQmx.RangeMapScale, ch11Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch12Scale As NationalInstruments.DAQmx.RangeMapScale, ch13Scale As NationalInstruments.DAQmx.RangeMapScale, _ ch14Scale As NationalInstruments.DAQmx.RangeMapScale, ch15Scale As NationalInstruments.DAQmx.RangeMapScale ''' <summary> ''' Initializes a new instance of the component. ''' </summary> Protected Overrides Sub Initialize() MyBase.Initialize() 'TODO: Perform custom initialization here. ' This method is called when the component is created. End Sub ''' <summary> ''' Clean up any resources being used. ''' </summary> ''' <param name="disposing">True if managed resources need to be disposed; otherwise, False.</param> Protected Overrides Sub Dispose(ByVal disposing As Boolean) 'TODO: Perform custom clean-up here. ' ' Refer to "Implementing a Dispose Method" in the .NET Framework documentation for more ' information on the Disposable Pattern. If disposing Then End If MyBase.Dispose(disposing) End Sub ''' <summary> ''' Raises the TaskCreated event. ''' </summary> ''' <param name="e">The event argument of the TaskCreated event.</param> Protected Overrides Sub OnTaskCreated(ByVal e As EventArgs) 'TODO: Perform custom DAQmx task configuration, such as advanced timing and triggering, here. ' ' Refer to "Adding Custom Functionality to a .NET DAQ Component" in the NI Measurement ' Studio Help for an example of advanced DAQmx task configuration. 'Dim arrayVoltMin() As NationalInstruments.UI.WindowsForms.NumericEditArray ch0 = Task.AIChannels(0) ch1 = Task.AIChannels(1) ch2 = Task.AIChannels(2) ch3 = Task.AIChannels(3) ch4 = Task.AIChannels(4) ch5 = Task.AIChannels(5) ch6 = Task.AIChannels(6) ch7 = Task.AIChannels(7) 'ch8 = Task.AIChannels(8) 'ch9 = Task.AIChannels(9) 'ch10 = Task.AIChannels(10) 'ch11 = Task.AIChannels(11) 'ch12 = Task.AIChannels(12) 'ch13 = Task.AIChannels(13) 'ch14 = Task.AIChannels(14) 'ch15 = Task.AIChannels(15) ch0Scale.PreScaledMin = frmMain.arrayVoltMin(0).Value ch0Scale.PreScaledMax = frmMain.arrayVoltMax(0).Value ch0Scale.ScaledMin = frmMain.arrayScaleMin(0).Value ch0Scale.ScaledMax = frmMain.arrayScaleMax(0).Value Task.Control(TaskAction.Verify) MyBase.OnTaskCreated(e) End Sub Public Sub SetTaskRange(ByVal minRange As Double, ByVal maxRange As Double) 'If ch0 Is Nothing Then 'OnTaskCreated(Nothing) 'End If 'If minRange > maxRange Then ' Exit Sub ' End If 'ch0.RangeLow = minRange 'ch0.RangeHigh = maxRange 'ch0.CustomScaleName = "test" 'ch0Scale.PreScaledMin = frmMain.arrayVoltMin(0).Value End Sub End Class
04-16-2015 09:34 AM
As far as I can tell here, the main problem I see is, that there's no declaration of the frmMain object, are you doing this in another portion of code here? Since as far as I can tell there's no problem with the declaration of the scales here.
