Help with NullReferenceException in "OnTaskCreated"
What am I doing wrong here and what do I need to do to fix it??  The following code is in the "OnTaskCreated" sub created by MS for custom task settings.  I am declaring the scales (ch0Scale, ch1Scale, ...) above this code in the same Partial Public Class DaqTask1Component.  What do I need to set the scale to and where in the code so that I am no longer getting the NullReferenceException error?
Thank you for any assistance provided.
    Private ch0 As AIChannel, ch1 As AIChannel, ch2 As AIChannel, ch3 As AIChannel, ch4 As AIChannel, ch5 As AIChannel, _
        ch6 As AIChannel, ch7 As AIChannel, ch8 As AIChannel, ch9 As AIChannel, ch10 As AIChannel, ch11 As AIChannel, _
        ch12 As AIChannel, ch13 As AIChannel, ch14 As AIChannel, ch15 As AIChannel
    Private ch0Scale As NationalInstruments.DAQmx.RangeMapScale, ch1Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch2Scale As NationalInstruments.DAQmx.RangeMapScale, ch3Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch4Scale As NationalInstruments.DAQmx.RangeMapScale, ch5Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch6Scale As NationalInstruments.DAQmx.RangeMapScale, ch7Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch8Scale As NationalInstruments.DAQmx.RangeMapScale, ch9Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch10Scale As NationalInstruments.DAQmx.RangeMapScale, ch11Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch12Scale As NationalInstruments.DAQmx.RangeMapScale, ch13Scale As NationalInstruments.DAQmx.RangeMapScale, _
        ch14Scale As NationalInstruments.DAQmx.RangeMapScale, ch15Scale As NationalInstruments.DAQmx.RangeMapScale
    ''' <summary>
    ''' Initializes a new instance of the component.
    ''' </summary>
    Protected Overrides Sub Initialize()
        MyBase.Initialize()
        'TODO: Perform custom initialization here.
        '      This method is called when the component is created.
    End Sub
    ''' <summary>
    ''' Clean up any resources being used.
    ''' </summary>
    ''' <param name="disposing">True if managed resources need to be disposed; otherwise, False.</param>
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        'TODO: Perform custom clean-up here.
        '      Refer to "Implementing a Dispose Method" in the .NET Framework documentation for more
        '      information on the Disposable Pattern.
        If disposing Then
        End If
        MyBase.Dispose(disposing)
    End Sub
    ''' <summary>
    ''' Raises the TaskCreated event.
    ''' </summary>
    ''' <param name="e">The event argument of the TaskCreated event.</param>
    Protected Overrides Sub OnTaskCreated(ByVal e As EventArgs)
        'TODO: Perform custom DAQmx task configuration, such as advanced timing and triggering, here.
        '      Refer to "Adding Custom Functionality to a .NET DAQ Component" in the NI Measurement
        '      Studio Help for an example of advanced DAQmx task configuration.
        'Dim arrayVoltMin() As NationalInstruments.UI.WindowsForms.NumericEditArray
        ch0 = Task.AIChannels(0)
        ch1 = Task.AIChannels(1)
        ch2 = Task.AIChannels(2)
        ch3 = Task.AIChannels(3)
        ch4 = Task.AIChannels(4)
        ch5 = Task.AIChannels(5)
        ch6 = Task.AIChannels(6)
        ch7 = Task.AIChannels(7)
        'ch8 = Task.AIChannels(8)
        'ch9 = Task.AIChannels(9)
        'ch10 = Task.AIChannels(10)
        'ch11 = Task.AIChannels(11)
        'ch12 = Task.AIChannels(12)
        'ch13 = Task.AIChannels(13)
        'ch14 = Task.AIChannels(14)
        'ch15 = Task.AIChannels(15)
        ch0Scale.PreScaledMin = frmMain.arrayVoltMin(0).Value
        ch0Scale.PreScaledMax = frmMain.arrayVoltMax(0).Value
        ch0Scale.ScaledMin = frmMain.arrayScaleMin(0).Value
        ch0Scale.ScaledMax = frmMain.arrayScaleMax(0).Value
        Task.Control(TaskAction.Verify)
        MyBase.OnTaskCreated(e)
    End Sub
    Public Sub SetTaskRange(ByVal minRange As Double, ByVal maxRange As Double)
        'If ch0 Is Nothing Then
        'OnTaskCreated(Nothing)
        'End If
        'If minRange > maxRange Then
        ' Exit Sub
        ' End If
        'ch0.RangeLow = minRange
        'ch0.RangeHigh = maxRange
        'ch0.CustomScaleName = "test"
        'ch0Scale.PreScaledMin = frmMain.arrayVoltMin(0).Value
    End Sub
End Class
(4,026 Views)
As far as I can tell here, the main problem I see is, that there's no declaration of the frmMain object, are you doing this in another portion of code here? Since as far as I can tell there's no problem with the declaration of the scales here.
(3,987 Views)
