Get device serial number via .NET
Hi
I would like to get the serial number of the device in the pci slot.
I was trying to use the NationalInstruments.DAQmx.Device class and the
serialnumber property.
Private
NIDevice As NationalInstruments.DAQmx.Device
TheSourceID = NIDevice.SerialNumber
The problem is that I don't know how to point to the correct pci slot to get the serial number of the device. I cannot find a function which allow me to set the pci slot number before I can read the SerialNumber.
Please advice
(5,349 Views)
Hi Chee,
The following knowledge base article should answer your question:
Programmatically Query the Serial Number of a DAQ Device
You don't need the slot number. Just provide the daq device name to the function.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,340 Views)
The article is based on LabView. I am using .NET and  DAQmxGetDevSerialNum does not exist in .NET.
I have tried to look for it for it is not there. Please advice.
(5,339 Views)
Hi Chee,
You would say something like:
NationalInstruments.DAQmx.Device myDevice = DaqSystem.Local.LoadDevice("dev1");
long serialNum;
serialNum = myDevice.SerialNumber;
Best Regards,
Jonathan N.
(5,333 Views)
I have a cfp-180x I have tried to use DAQmx but I have the following errors:
Error 3 The type or namespace name 'DAQmx' does not exist in the namespace 'NationalInstruments' (are you missing an assembly reference?)
Error 4 The name 'DaqSystem' does not exist in the current context
Do you have sugggestion?
(3,707 Views)
Start your own thread.
(3,697 Views)
