01-06-2016 08:40 AM
I would like to retrieve the serial number of my cfp-180X with measurement studio.
Should be perfect if I can retrieve, also, the serial number of the AI-110 installed on the cfp.
Do you how to do?
01-06-2016 09:18 AM
Do you how to do?
What makes you think that Measurement Studio works with Compact FIeldPoint hardware? All I see is LabVIEW.
01-06-2016 09:42 AM
Hi nyc,
I can retrieve the serial number from NI MAX.
Pleae see the attached screenshot.
01-06-2016 09:59 AM
Hi nyc,
And that proves what?
01-06-2016 01:55 PM
Is a my assumption,
if NI-MAX (not a labview) can access this information probably there is a way to read the serial number.
01-06-2016 02:22 PM - edited 01-06-2016 02:42 PM
Is a my assumption,
IF there is a way to access CFP via .NET, National Instruments isn't sharing the information.
All they are selling with it is LabVIEW.
You'll have to assume on your own.
01-06-2016 02:42 PM
Wha do you mean?
We are using measurement studio to access the network variable to read value from CFP since 2010
I'm not understanding your point.
Bye!
01-06-2016 03:02 PM
Wha do you mean?
Bye!
I haven't been able to find any documentation. That is what I mean.
If you have found it, go for it.
01-07-2016 03:21 PM
Hi karpediemnowUSA,
Most of the fucntionality of NI MAX can be done programmatically using the NI System Configuration API. For example, in LabVIEW, a property node from the System Configuration API can be used to find the serial number of NI hardware. If it is possible to programmatically find your cFP serial number it would be through this API. The API is compatible with Measurement Studio 2003, 2005, and 2008. I recommend looking at the link below.
Welcome to the System Configuration API:https://decibel.ni.com/content/docs/DOC-13216
Best Regards,
Andy
01-08-2016 10:36 AM
Thanks Andy,
Do you know how to use NI System Configuration API in .net framework?
I cannot find any example.
