02-18-2008 05:41 PM
02-19-2008 03:50 PM
Hi Argneka
I see that you opened a service request with one of our applications engineers. For others reading this thread the ContWriteDigChan_Burst example uses I/O Burst Mode, but this mode is not supported on the PCI-6025E card. That mode is only available on the DIO-32HS/653x, you can verify that here. You can also verify the I/O modes supported by your card in the card's user manual. I hope this is helpful,
02-20-2008 06:15 PM
Is there a way to pulse the output of the 6023E or 6025E? I see that Measurment Studio has a .NET function for Waveform. Can I generate a waveform to the particular DIO channel. I can easily turn on and off the channel but I need to pulse the output or send a waveform that is PWM. If the 6023E / 6025E cannot do this then what card can.
Argula
02-25-2008 11:36 AM
Hi Argneka,
