04-02-2015 01:18 AM
Hello guys,
How to forcibly read samples from Alchannel objects in a task before trigger signal comes?
Thanks..
05-07-2015 08:02 AM
Did you figure this out? When you mention forcing a read do you mean just performing a read? I haven't worked with triggers before but I would suspect you could set your trigger for a certain set of criteria and still perform a read of all the AI channels. You would want to put some protection around your code to make sure your trigger even can't occur during a manual read but that would just be some basic source code I think.
05-13-2015 08:20 PM
Hi ASCE_33,
If you use AI channels of a Scope, data will be recorded before trigger.
If you use a DAQ module, I’m afraid it’s unable to read data before trigger coming.
