02-03-2015 10:16 AM
First, I'm developping with Visual Studio 2010, Measurement Studio 2013, NI-DAQmx 14.0, Framework 4.0, Windows 7, NI-PCI 6250
At the date of today, i'm testing C# & Measurement studio / daq mx and I don't use daq assistant (see post : I created here)
I'm acquiring an analog signal, plotting it, get an FFT and plotting it.
I would like to make some real time analysis thanks to the FFT plot.
At start my FFT is shown on all the frequency domain I study (10 Hz to 350kHz)
I changed Range thanks to a toolstrip I made : Start Freq, Stop Freq.
I get my zoom, cool.
but how can I make my library reprocess the FFT between the start and stop frequency to get a better definition ?
If I do things wrong from the start any advice is welcome 🙂
Code :
private void AnalogInCallback(IAsyncResult ar) { try { if (taskRunning) { //Read the available data from the channels data = analogInReader.EndReadMultiSample(ar); //data is double[,] //Plot your data here waveformGraph1.PlotYMultiple(data); analogInReader.BeginReadMultiSample(SAMPLES_PER_CHANNEL, analogCallback, null); //repetition de la ligne du Start_Click pour MAJ dans le runtime // Generate the complex signal and apply the selected window to it NationalInstruments.ComplexDouble[] complexSignal = new NationalInstruments.ComplexDouble[SAMPLES_PER_CHANNEL - 1]; for (int i = 0; i < complexSignal.Length; i++) { complexSignal[i] = new NationalInstruments.ComplexDouble(data[0, i], data[0, i]); } ScaledWindow.CreateHammingWindow(); // Display the power spectrum double[] powerSpectrum = Transforms.PowerSpectrum(complexSignal); freqDomainWaveformGraph.PlotY(powerSpectrum); }
private void toolStripStart_Click(object sender, EventArgs e) { if (!taskRunning) { try { myTask = new Task("aiTask"); //Create a virtual channel myTask.AIChannels.CreateVoltageChannel("Dev1/Ai0", "aiChannel", AITerminalConfiguration.Differential, Convert.ToDouble("-2"), Convert.ToDouble("+2"), AIVoltageUnits.Volts); //Configure the timing parameters myTask.Timing.ConfigureSampleClock("", SAMPLE_FREQUENCY, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, SAMPLES_PER_CHANNEL); //Verify the Task myTask.Control(TaskAction.Verify); taskRunning = true; analogInReader = new AnalogMultiChannelReader(myTask.Stream); //analogInReader.SynchronizingObject = this; analogCallback = new AsyncCallback(AnalogInCallback); analogInReader.BeginReadMultiSample(SAMPLES_PER_CHANNEL, analogCallback, null); }
When I click on OK button in my toolstrip
private void butt_FreqDomain_OK_Click(object sender, EventArgs e) { double a, b, c; a = Double.Parse(text_StartFreq.Text); b = Double.Parse(text_StopFreq.Text); c = a + (b - a)/2; text_CenterFreq.Text = c.ToString(); freqDomainPlot.XAxis.Range = new NationalInstruments.UI.Range(Double.Parse(text_StartFreq.Text), Double.Parse(text_StopFreq.Text)); }
Captures :
without zoom
With zoom
Second question :
I'm generating a 55kHz Wave signal, where is the problem ? why the fundamental is at 55002 ~55003 Hz ?
Thank you in advance
02-19-2015 11:14 AM
If you want to have more precision you could take more point using FFT zero padding : http://www.bitweenie.com/listings/fft-zero-padding/
An another solution is to use the FFT Zoom function which is use in CVI labwindows, we can find it in “NI Spectral Measurement Toolkit C”.
Here is the explanation : http://www.ni.com/white-paper/3995/en/
I hope this could answer your first question.
Maxime G. | Application Engineer
National Instruments France
