12-17-2006 08:52 PM
12-18-2006 10:03 AM
We did not see an attached image to your original post. Please could you attach the image again so that we can see the error and investigate the problem?
Regarding your second issue about aligning controls in the overflow, the ToolStrip base class (from which the Instrument Control Strip derives) has hard-coded the layout of controls in the overflow to a flow layout. This basically means that you have very little influence over how the controls in the overflow are aligned. I have not tested this but you might be able to set the width and height of the overflow to work around this limitation.
12-18-2006 04:42 PM
12-18-2006 05:13 PM
I have not been able to reproduce the problem you are having. I tried deleting individual ToolStripPropertyEditor objects inside the InstrumentControlStrip at design-time by right clicking on the object and selecting Delete from the menu. I also used the Delete keyboard key to delete items and did not get any errors. I tried this with the Enterprise edition of Measurement Studio.
Please could you give us more information about your particular scenario, such as which edition of Measurement Studio 8.1 you have installed. I would also like to know if the ToolStripPropertyEditor objects have the Source property set before attempting to delete them. If so, what is the Source? Is it properties of other Measurement Studio controls or .NET Framework controls? What version of Visual Studio 2005 are you using (Standard, Professional, Enterprise, Express)? Do you have Visual Studio 2005 Service Pack 1 installed? If you can think of any other relevant information that might help us in reproducing the problem please can you provide that here.
12-18-2006 07:16 PM - edited 12-18-2006 07:16 PM
Message Edited by adamhb on 12-19-2006 11:17 AM
12-18-2006 07:26 PM
12-18-2006 07:41 PM
