We have managed to reproduce a drawing error within the NI Measurement studio 7.1 scatter graph. The exception trace was:
Overflow error.
at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
at System.Drawing.Graphics.DrawImage(Image image,
Single x, Single y, Single width, Single height)
at
NationalInstruments.Restricted.GraphicsInternal.DrawImage(Graphics
graphics, Image image, Single x, Single y)
at
graphics, Image image, PointF point)
at s.a(Graphics , PointF )
at s.a(PointF , Rectangle , Graphics )
at s.DrawForeground(ComponentDrawArgsInternal args)
at
NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal
, Rectangle , Boolean )
at
NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal
args, Rectangle clipRectangle)
at
at
at
at
at
at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal , Rectangle )
at NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)
at NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)
at
System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e,
Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message&
m) at System.Windows.Forms.Control.WndProc(Message&
m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at
System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32
msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at
System.Windows.Forms.ComponentManager.System.Windows.Forms.UnsafeNativeMethods+IMsoComponentManager.FPushMessageLoop(Int32
dwComponentID, Int32 reason, Int32 pvLoopData)
at
System.Windows.Forms.ThreadContext.RunMessageLoopInner(Int32 reason,
ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
Additional information:
The plots on the graph all have ProcessSpecialValues set to true.
Only one plot is visible.
As well as regular data values, we have also added NaN data values to
the plot. These are used to create gaps in the data (note - these gaps
are part of our user's requirements).
A cursor is visible, with snapmode = ToPlot
The error occurred immediately after the x-position of the cursor was
changed to match a gap in the data - i.e. an area containing NaN data
entries.
