When you write a value to a DAQ Card (i.e. 6251) on the Analog Output channel, that channel will hold the value until you update it. Updates come from things like updating the analog output with another DAQmx write, restarting the computer or resetting the device. I have posted a screenshot of an analog output that uses a simple software timed AO for a channel/task before I configure the timing and additional waveform. As you can see I output a 5 V signal with one DAQmx write. I then setup the timing and wrote a sine wave to the device. You can see the output stays high until I start the waveform generation. Is this what you are looking for?
If so, before you start anything with your setup/mass spectrometer is it possible just to call a single DAQmx write 1 channel 1 sample to set the value high. I was not sure what you meant by "
Since the profile repeats 200 times, it is not possible for me to buffer the
beginning of this profile with high values prior to beginning the experiment" so If this does not work can you please explain a little more about this? With the method I mentioned above, you just need to write data with auto start on for a single point DAQmx write. Then write your larger waveform that repeats 200 times.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
