05-18-2006 11:41 PM
05-19-2006 05:45 PM
Stuman,
Check out this forum post. It should get you started, I would also recommend checking out the C reference manual. You can find it on your machine at the following location:
Start >> Programs >> National Instruments >> NI-DAQ >> Traditional NI-DAQ Function Reference Help
Also installed are some VB 6 examples, now you will have to access the Traditional Driver calls through function calls to the .dll as that post mentions, but at least those examples will show you how things need to be programmed. Here is where they are located:
C:\Program Files\National Instruments\NI-DAQ\Examples\Visual Basic 6.0
I hope that helps you out.-GDE
