We don't exactly have an example that will do that. With that said, you could implement this in two different ways.
- Use a Cursor and while you scroll your cursor, you can display the value that it is currently at.
- You can display Annotations to display the values at certain points.
Below are two locations for examples on using Cursors or Annotations.
C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\UI\WindowsForms\Graph\CustomAnnotations
C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\UI\WindowsForms\Graph\Cursors
