Closed-loop PID Controller with Measurement Studio
I'm in the process of implementing a PID controller in C# with Measurement Studio. I realise that Windows XP cannot provide real-time performance, but as the cycle-time is quite slow I'm wondering whether this is really a problem.
I'm intending to have the controller driven from the .NET Timer class, and will be be using a cycle-time of 100mS.
Although I'm familiar with the implementation of a PID, any example code for C# would be very useful.
Any recommendations or advice on what I'm doing will be greatly appreciated!
Many thanks,
Michael
(4,250 Views)
If you can use .NET Framework 2.0, consider using the Stopwatch class instead of the Timer class. Stopwatch utilizes the computer's multimedia timer (if available) to provide better accuracy and resolution than the Timer class.
(4,243 Views)
Drohacek,
Although my gratitude is a little late, I would like to thank you for pointing me in the direction of the Stopwatch class, this has been very useful.
Many thanks,
Michael
(4,157 Views)
You're welcome; I glad it was helpful.
(4,134 Views)
BTW, what PID controller can be programmed with C#?  What programming hardware do you need to do this?
Scott
(4,132 Views)
Nervermind, misunderstood topic.
(4,121 Views)
