05-01-2014 09:12 AM
I need to be able to change the status of the USER1 LED on a cDAQ9139 chassis from my VS2010 C# application code. Can anyone point me in the direction of the DAQmx class/property/method I need to use?
Malcolm Sharp
Solved! Go to Solution.
05-06-2014 05:33 AM
Hi Malcolm,
Taking a look into this it looks like unfortunately the USER1 led is only available for access from the Real-time operating systems. There is no access to it available from the DAQmx driver, when running windows on the cdaq.
Best Regards,
05-08-2014 10:08 AM
Thanks for the answer. I guess I'll have to come up with some other method of indicating the operating status when using the cDAQ9138 as a 'headless' system!
Malcolm Sharp
