Can't get Graph.DataSource to work in WPF i (threading issue?)
Thank you.  I will try the array solution.
Message 11 of 16
(2,648 Views)
Hi Phansen,
I'm having an issue and would appreciate your help.
For some reason one dimensional array works but 2D does not.  I get "Parameter count mismatch." exception.
Do you see the issue here?  Thank you!
        private void GetData(Action<object> actionPlotData)
            //double[] testData = new double[] { 1, 2, 3, 4 }; // This works
            double[][] testData = new double[2][]; // This does not
            testData[0] = new double[] { 1, 2, 3, 4 };
            testData[1] = new double[] { 2, 4, 6, 8 };
Dispatcher.BeginInvoke(actionPlotData, testData); } private async void ButtonAcquirePackets_Click(object sender, RoutedEventArgs e) { await Task.Run(() => GetData(data => GraphNode0.DataSource = data)); }
Message 12 of 16
(973 Views)
Accepted by topic author kirko7
I believe the issue is BeginInvoke expects a params object[] for the arguments to the delegate. A double[] can't be implicitly converted to object[] (because it would require boxing every double), but double[][] can be (because a double[] array is directly compatible with object). So BeginInvoke thinks you are trying to call an Action<object> method with two parameters, testData[0] and testData[1], instead of a single parameter, testData.
To fix this, you just need to be explicit about the params object[] argument:
    Dispatcher.BeginInvoke(actionPlotData, new object[] { testData });
~ Paul H
Message 13 of 16
(970 Views)
Thank you very much!
That did it!
Message 14 of 16
(967 Views)
This gotta be my last question because this thread pretty much covers everything.  But here's the last one from me...
I have a list of Graphs because I have 8 sets of data from different nodes.  But I acquire this data at the same time from the same DAS.  So I need to update 8 Graphs at the same time and I have them in the List in order to loop through them.
Graphs = new List<Graph>();
Graphs.Add(GraphNode0);
Graphs.Add(GraphNode1);
Graphs.Add(GraphNode2);
Graphs.Add(GraphNode3);
Graphs.Add(GraphNode4);
Graphs.Add(GraphNode5);
Graphs.Add(GraphNode6);
Graphs.Add(GraphNode7);
Is it possible to modify this call to accept List of Graphs?
private async void ButtonAcquirePackets_Click()
     // Get my data here...
double[][] testData = Scan();
// Loop here and somehow index into List of Graphs...? Dispatcher.BeginInvoke(actionPlotData, new object[] { testData }); }
I'm actually curious if this is even a good design.  Thank you in advance!
Message 15 of 16
(961 Views)
I don't think there's anything wrong with dispatching a single method to update all the relevant graphs. As shown in previous exmples in this thread (here and here), the delegate passed to BeginInvoke can have any type, so Action<Graph[], object[]>, or Action<IList<Graph>, double[][]>, or etc., would work just as well as Action<object>.
~ Paul H
Message 16 of 16
(959 Views)
