03-06-2007 08:29 PM
03-07-2007 03:45 PM
03-07-2007 09:04 PM
Thanks for your reply. Basically, I follow the example of VC# GenerateAnalogVoltage_IntClk with asyn write AO. I am using a digital oscilloscope to monitor the output AO signal from PCI-6071E. I tested timing sample rate as: 1k, 10k, 100k, 1M, 1.25MS/s. The digital oscilloscope can show the time length of the generated pulse trains. I am using Finite sample mode, the number of sample per channel is: 1k, 10k, 100k, 1M, 1.25MS for each above sampling rate. If the timing function works, then all pulse train should last about 1 second. But it seems that no matter what sampling rate was set, the resulted actual sampling rate is 1.25MS/s, which is the maximum hardware sampling rate.
Chen.
03-08-2007 08:05 AM
03-08-2007 04:55 PM
I tried to generated single square wave of period of 1 second with 50% duty cycle (the duration will be 1 second too).
Here are the the list of results:
set sampl rate, number of samples per channel, estimated duration from outout of digital oscilloscope:
1.25MS/s, 1.25MS, 1 second
1MS/s, 1MS, 0.75 second
100KS/s, 100KS, 75ms (milli second)
10KS/s, 10KS, 7.5ms
1KS/s, 1KS, 0.75ms
THe correct results for all above list should be 1
second duration for each case.
I like to try to export the sample clock for the task to a PFI line and look at that directly on. Can you post a sample C# code for this? And can you tell me how to connect the PFI line signal out? The PFI line is signal, is that ground same ground as DGN (digital ground)?
Thanks for your help,
Chen.
03-08-2007 05:32 PM
03-10-2007 07:33 AM
03-12-2007 04:48 PM
03-13-2007 10:52 AM
03-13-2007 02:02 PM
