03-13-2007 02:48 PM
03-13-2007 02:54 PM
03-13-2007 02:57 PM
03-13-2007 03:25 PM
03-13-2007 03:40 PM
Sorry, I am pretty confused by .Net AO write methods now. Why for 250 samples, actual sample clock rate 50k, 500k, they got the same actual time length? The BegineWriteMultiSample write a double[] data into channel, for axample 250 data point. Is that task.Timing.ConfigureSampleClock("",sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMOde.FiniteSamples, data.Length) determine the speed of wrting samples? Because it is obvious no time increment information from double[] data.
If so, then for higher sampleRate, it should result a shorter duration of signal. Am i right? Should be do any else settin for timing clock?
Chen.
03-13-2007 03:56 PM
03-13-2007 04:09 PM
03-13-2007 05:48 PM
