03-13-2006 09:46 AM
03-14-2006 08:34 AM
03-15-2006 01:55 PM
03-21-2006 12:53 PM
After much pain and agony, I discovered the cause of this problem. The 3 machines that properly built the wrapper libraries for the CW3DGraph .OCX had .NET Framework 1.1 SP1 installed. The 2 machines that failed to build the wrapper libraries correctly had .NET Framework 1.1 installed. I upgraded the 2 failing machines and now the overloaded functions that I needed are exposed properly.
I discovered the different versions when I was running the Aximp utility from a command prompt on different machines. I also discovered the same problem (no overloaded functions) when creating the wrapper libraries for CWUI.OCX. Although there's not many developers using Measurement Studio as I am, you will want to put this in the NI knowledge base.
Eric Strennen
