Hi John,
Are you already using the AnalogWaveform<TData> class in your application? If so, then you can access the timestamp through the Timing property. If you are not using this class, then a good starting point is the shipping example GlobalContinuousAI (located in the <MeasurementStudioVS2005>\DotNET\Examples\DAQmxWithUI\GlobalContinuousAI folder) which uses this class along with the AnalogMultiChannelRead class. In this example, adding a statement like: data(0).Timing.TimeStamp would allow you to get/set the timestamp for the first channel of data. Note that the return type of the EndReadWaveform method is AnalogWaveform<TData> which means the timing information is set based off the execution of the AI task. Otherwise, the timing property is set to Empty when creating an analog waveform using a constructor.
As far as the AnalogWaveformSample<TData> class goes, you can look at it just as a sample of the AnalogWaveform<TData> class (as it states in the help) which is why there is an Owner property of AnalogWaveform<TData> type. Thus, the timestamp will be set if the Owner's Timing property is not Empty. Otherwise, no timestamp will be available. Let me know if this helps.
Have a great day,
Ecleamus Ricks, Jr.
Applications Engineer
